Pass Data between while loops
I've two loops and just need to pass some values (say 3-4 values) from main loop to secondary loop only once. What is the best way to do it?
Thanks in advance.
(4,681 Views)
Accepted by topic author PadmanabanJ
Hi Padma,
use locals, globals, notifier, channels, ...
Put those items in a (typedefined) cluster to ease handling.
(4,669 Views)
How about using Queues?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,656 Views)
Please define "only once".  Do you want the second loop to just use the latest value for a variable(s) that the first loop wrote or do you want to send a message to the second loop to update some state information?  In the first scenario, I would use global variables.  In the second scenario, I would use a Queue or User Event.
(4,647 Views)
