Pass container object to testStand via queue
I try to use queue mechanism to pass container data from labVIEW to TestStand.
In TesStand I create a queue, lunch VI and waiting for incoming queue element.
In LabVIEW I try to send some data to TestStand as container (cluster).
Before this, I tried to pass numeric data and then everything was OK. Problem is only with container.
In TestStand I created custom type. Can someone help me with this issue.
Thanks in advance and best regards.
(3,270 Views)
Accepted by frg.1906
I found resolution, I changed VALUTE TYPE on “new property object” to “Name type” and now everything is correctly :manvery-happy:
(3,256 Views)
Would please attach your VI and your TestStand sequence ?
It would be helpfull for me as I want to do some similars synchronisations between Labview and TestStand.
Thanks in advance.
(3,217 Views)
Here you are. keep in minde, that this is only "testing" version.
(3,212 Views)
Hi, I found it don't work. The VI have an error:Queue_test.vi->Queue_test.vi.ProxyCaller, Exception occured in TSAPI: Could not find type 'kontener'.
(3,134 Views)
