Passing Data with Many Senders at Multiple Rates for Logging
@apok wrote:
did you look at this in the find example>>Queue Multiplexer.vi....."Many-Into-One" Smiley Wink
I went ahead and re-did the example according to what I will be using it for.  It logs a TDMS file to disk wherever the VI is located.
There are tons of 0's throughout the data, which I can't have in the data set (because this data will also go through a calculations phase and the 0's will kill my calcs).  The only thing I can think to do is multiple independent streams.  I'm still not sure how the calcs will work out, but this logging will not work.  (I did this example with just 1 channel group.  My final will have multiple channel groups according to the logging rate.  I was just trying to see how the single pipe with all the data would work for this example).  Thanks for any help.
Nathan - Certified LabVIEW Developer
Message 11 of 23
(3,984 Views)
how about changing the 0's in the cluster constant ton NaN, then make the writes in the Data Retrieval Loop conditional and check for NaN.
Nice loop labeling by the way. Smiley Happy
Regards
Florian
Message 12 of 23
(3,970 Views)
whats happening is you are introducing no data on the rest of the elements in one loop, like wise on the other two loops...therefore "0"s on the end results. assign a different queue for each data enqueued....
Spoiler
Message 13 of 23
(3,950 Views)
That's what I figured it would boil down to, I've beating my head against the wall all day trying to figure the most elegant way to do this (this is just a small subset of the problem, I'm trying to keep the number of queues and such down to a minimum, notifiers with the 1:N way of doing things might become my friend).  Thanks for the help.
Message 14 of 23
(3,947 Views)
Accepted by Nathan_S
You can avoid writing the zeros with one small mod
Message 15 of 23
(3,940 Views)
Jeff,
think yours is the answer!....an elegant way?
Message 16 of 23
(3,937 Views)
This is great.  Thanks everyone for the help.
Message 17 of 23
(3,911 Views)
You are quite welcome.
Multiple producer multichannel consumer loops such as this one  Several producers, each with its own destination, but constrained by a common element (Bus, File, etc...) almost have to contain source info in the queue data.  A hard lesson to learn from scratch and, trust me you can go down many dead-ends and dark allys finding the trick!  One of the best features of these forums is the ability to learn best methods and practices for these trickier problems.  Glad I could help.
Message 18 of 23
(3,893 Views)
Well said Jeff.
Message 19 of 23
(3,871 Views)
Jeff,
Would you post vi for the solution?
Thanks!
Message 20 of 23
(3,558 Views)
