Passing a boolean between loops
Hi Hawkme,
What aputman has put up will ensure the For loop runs on a TRUE state to the case structure. This, quite simply, is because the For loop is in the TRUE case of the Case Statement. By clicking the arrows on either side of the case value at the top of the structure, you can switch between cases. Otherwise, if you have a scroll wheel on your mouse you can roll when the cursor is inside the structure.
Message 11 of 28
(2,144 Views)
So can I infer from your response that you believe this picture, the way it is weird, should pass the true value to the the case statement which will then execute the FOR loop?
Message 12 of 28
(2,133 Views)
hmmm....okay, you are new at this...let me explain further so you can manage this.
In short - yes, to your question.
Why - because the boolean state of TRUE is being passed to the Case Selector (the question mark on the side of the case statement), which will run any code in the TRUE case. The FOR loop is in the TRUE case.
Message 13 of 28
(2,124 Views)
Haha, yes I am new, it's been a learn as I go kind of thing. Okay, that's what I wanted to know, if the true boolean could be passed this way while in a loop to another nested loop. I have been haivng trouble with this so I was unsure if my logic was wrong or something. I must have messed up some wiring that I'll have to check out.
Message 14 of 28
(2,114 Views)
In the wired diagram Aputman put up there are a couple of housekeeping rules you'll need to follow, such as:
1) wire the While loop end condition (Red button at bottom right) to a boolean value or button. With the red dot you have a 'Stop If True' condition. Clicking on it it will change to a 'Stop if False' condition. Wire it up appropriately so you can always escape the loop (finish or close the program).
2) As it is wired, a TRUE value will always be sent to the Case Selector. This can be changed to a button, control, indicator, global, etc.
See how you go. 😉
Message 15 of 28
(2,105 Views)
Since you are new to all of this, might I recommend some free online training...
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
Message 16 of 28
(2,071 Views)
thanks Crossrulz, for your inspiring comment and inclusion in this +1 post fiesta. You are welcome to provide us further with your experience and great learning.
Sorry to single you out, there have been a few like yourself who enjoy posting threads of wisdom that help no-one. One day, I too hope to be an NI Knight, so that I may go forth and strike down the inexperienced.
Message 17 of 28
(2,064 Views)
David,
That is an incredibly rude comment. You can continue to help students cheat or stay out of the forums. Providing links to tutorials is a way for lazy students to actually learn.
Message 18 of 28
(2,054 Views)
How is providing free tutorials "striking down the inexperienced"?  If I was new to this, those are the kinds of posts that i would welcome.  Show some respect man.
aputman
Message 19 of 28
(2,050 Views)
Tell that to my ~1200 marked solutions.
I was trying to avoid this, but since a couple of others stood up for me...Look, the OP flat out said they were new.  I was trying to be helpful in letting them know there is training out there for FREE that they could go to and get a lot of their answers instead of going back and forth with us here.  So, in a way, that was actually cutting into my possible post count.
David_NMRSA wrote:  One day, I too hope to be an NI Knight, so that I may go forth and strike down the inexperienced.
Look closer.  I'm not a Knight of NI (yet).  I try very hard not to "strike down" anybody.  There are a few topics I will get animate about simply because they are major pet peeves of mine.  But simply telling somebody that there are other places for help is not "striking down" anybody.
Message 20 of 28
(2,037 Views)
