Passing from max to min value
I created a .txt file from that file path that contains a only a number.
I wanted to extract that number and put it on a display that could show the variations on that .txt file.
Message 11 of 17
(2,386 Views)
Still not clear on what you are trying to do.
But there is a function called path to string.  You can use that on the file path then use string functions in order to pick the number out of the filename.
Message 12 of 17
(2,374 Views)
I have these files on the anex.
I want to extract there numbers and put it on a indicator.
Problem is that the write/read function, saves one at the time in this .txt file, but i want to read it as a whole, not in separet parts
Message 13 of 17
(2,364 Views)
What is "anex"?
So you need to go through a list of filenames and collect data from each of those file names?
Now you need to create an array of filenames.  (Look at List Directory or some function with a name like that.)  Then feed that array into a loop with auto-indexing.
Message 14 of 17
(2,356 Views)
Will try that. Thank you 🙂
Message 15 of 17
(2,336 Views)
@Janitor wrote:
Thanks for the tips but right know i dont have time to build sub-VI´s.
In regards to the indicator, that only creates a indicator of the path file, what i want is the number inside the path, in this case in the .txt file.
Did someone tell you to build a subVI?
No one has time for subVIs.  Then they get fired and I am left to do the cleanup.
Bill
CLD
(Mid-Level minion.)
Message 16 of 17
(2,281 Views)
You don't have time to _not_ build sub vi's. They'll save lots of time down the line, or even down the day ...
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 17 of 17
(2,240 Views)
