Passing on large Arrays within an Eventstructure
I've got a for-loop within an event structure which creates a large array(~650mb) via auto-index-tunnel. In the next step I want to read this array in another event. Every approach I've tried so far copies this large array at some point.
The best I could come up with until now, is to store it in a global variable. But when Labview reads for the global variable it creates a hole copy, even though I only need a small part of this array.
I've attached a vi to show my basic structure.
Matthias
Message 1 of 8
(3,675 Views)
Matthias,
you are looking for a shift register....
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(3,673 Views)
I thought about adding shift register to the big while-loop, too. But the "Show Buffer allocation"-Tool indicataes that the auto-index-tunnel creates an array which is then copied to the shiftregister. Or am I wrong?
Message 3 of 8
(3,666 Views)
Accepted by steinhagelvoll
If you do everything right, there wont be an additional copy.
Make it a rule of thumb: Branching a wire creates copies, as do indicators. But shift registers keep data in place.
Norbert
Norbert
Expert: Geometry
Message 4 of 8
(3,661 Views)
Ok. Sounds good.
But when I want to get a certain element using "index array" without loosing my array I have to use branching. Does Labview copy the hole array and extract the element afterwards or does it just copy the single element?
Message 5 of 8
(3,647 Views)
Since you are not going to manipulate the whole array itself, LV will not copy the array.
Depending on the code following the "index" function, the specific element is copied out of the array and the manipulation is done on that copy.
Norbert
Norbert
Expert: Geometry
Message 6 of 8
(3,634 Views)
If I only use the index-array-function to access my array wouldn't the method with the global variable be equivalent? It's just a much smaller code.
Message 7 of 8
(3,620 Views)
each instance of a Global read mandates a buffer for each. SInce LV does not know which global will be read when (due to multithreading) any time a global gets written a copy is stashed away for every global read.
Read this to learn about why globlas are concidered evil.
"Go, and sin global no more."
Ben
Message 8 of 8
(3,612 Views)
