Passing parameters to VIs
Using LV 6.1 with WIN 2000. I am wanting a way to pass several graph parameters to a SubVI without having to cluster properties together. I have several graphs that I need to pass serveral parameters each and would like a compact way to pass all parameters for an XY graph into a SubVI. Are references the way to go here? if so, does anyone have example code on this?
(2,858 Views)
I think references should be good for you. If you pass a reference then all the properties will be available in the subVI.
Watch the VI attached !
Julien
(2,858 Views)
References are really a way to interact with UI object, not a general
pointer to data. In LV, which is a value-based dataflow language, you
either pass the parameters individually, in an array if they are of the
same type, or in a cluster if they are not.
Greg McKaskle
(2,858 Views)
If I'm not mistaken, all data operations done on references must be done in the UI thread. Depending on what thread the sub-vi is normally running in, this can have severe performance issues.
Have a look here for more information.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,858 Views)
