Passing structure pointer to dll
The power of google. 😉
intvsteve
LabVIEW R&D
Message 11 of 13
(2,004 Views)
Hi guys!
First of all I'm sorry for my awful english! I have a big problem: maybe it's the same you are talking about in previous rows. I'm trying to use a dll in labview. I've found two situation once that I've solved and another one that is stopping me. I'm able to configure this kind of situation:
ls50errortype CALLTYPE Ls50P2Open(ls50p2apiconfiginfostruct &configinfo)
typedef struct  {
  ls50p2cardconfigstruct CardConfigInfo[MAXMFCARDS];
  int Ls50P2CardCount;
  ls50p2carddatastruct DataInfo[MAXMFCARDS][2];
}ls50p2apiconfiginfostruct;
I configure  ls50p2apiconfiginfostruct type with an array of unsigned 8-bit in "call lybrary function" interface and everything works properly!!!
But now look at the next example. My structure is different because now I have a pointer and I don't know how to do to configure this in call lybrary function labview window:
ls50errortype CALLTYPE Ls50P2LoadDecomSetupAndStart(pdecomsetupstruct &decomsetupdata)
typedef struct decomsetupstruct
   decompolaritycodetype eDataPolarity;
  bool                  bFACEnable;
  decomsubframemodetype eSyncMethod;
  bool                  bForceSync;
  short int             FrameSyncTolerance;
  bool                  bGMode;
} *pdecomsetupstruct;
 I don't know how to fix this problem because I don't understand if with labview visual tool is possible to set this situation. That pointer is making me insane 🙂
If you have a bit of time please help me my work must go on.
Best regards!
Francesco
Message 12 of 13
(1,985 Views)
sauel wrote:
.... My structure is different because now I have a pointer and I don't know how to do to configure this in call lybrary function labview window:
  bool                  bFACEnable;
  bool                  bForceSync;
  bool                  bGMode;
Best regards!
Francesco
If that function prototype is correct, then it's expecting a C++ reference to a pointer. If such is the case, then it's possible that the function itself could return a different pointer to the caller - and the LV Call Library Node does not support this. After all, LabVIEW cannot know how it should deallocate a pointer returned in such a fashion.
In this case, Francesco, you must write a wrapper DLL that converts between the LV data and this other type.
intvsteve
LabVIEW R&D
Message 13 of 13
(1,975 Views)
