Path Woes
The detailed help warns of this exact scenario (LV 2020 SP1)
"Partial paths, such as test\subtest, are not valid as array elements..."
Former Certified LabVIEW Developer (CLD)
Message 11 of 33
(1,985 Views)
@JÞB wrote:
@paul_cardinale wrote:
@AeroSoul wrote:
ah, so it's more for universality among different OS.
I operate exclusively on windows, so i usually just use strings.
Lacking a crystal ball, I don't assume that my code will never be used with a different file system; I consider such an assumption to be bad coding practice.
Try this improved method
I don't Amazon anymore (they sold me some counterfeit goods (at my age and grumpiness level, crap on me one time and you're on my s-list)).
Message 12 of 33
(1,981 Views)
Based on what you are explaining, it sounds like cryptomacia to me. I call it cryptomacia.
Message 13 of 33
(1,980 Views)
This remark already exists with LV15, the oldest version installed on my computer.
Message 14 of 33
(1,959 Views)
A "path to string" and then a "string to path"  'resolves' the problem.
Flattened data shows the differences:
Changing the flattened data to hex reveals that the path is actually internally stored as an array of items, and Array To Path simply put's each item in an array element
Here's another way to do it 'right' (on windows):
And that is what you'd expect Array of String to Path to do...
It's not a bug, it is somewhat unexpected:
Message 15 of 33
(1,946 Views)
That look will work only if the path element delimiter embedded in the strings matches the delimiter used by the current file system.
The reason that paths are a different data type from strings is to avoid the issue of different delimiters on different systems.
Message 16 of 33
(1,923 Views)
That look? Not sure what you mean...
Message 17 of 33
(1,897 Views)
That's a strange editing mistake.  I'll chalk it up to a brain cramp on my part.  It should read "That will work only ..."
Message 18 of 33
(1,883 Views)
A, maybe you mend "That loop will work only..." That makes sense and explains the typo.
I think we're in agreement here.
There are two flavors:
1) Use a loop and build path-> The strings can be compound, but must be system delimiters
2) Use an array -> Strings can't be compound.
Message 19 of 33
(1,872 Views)
Yes, that's what I "mend".  😀
Message 20 of 33
(1,833 Views)
