Pause the reading of a script file without stalling main while loop
@jedi.engineer wrote:
The only issue I have with this setup is the dequeue on the main loop. It throws an error and I'm not entirely sure why.
Your middle loop is finishing and releasing both queues, then your bottom loop is still going and trying to dequeue elements from a now-released queue.
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 31 of 39
(1,220 Views)
I just found that, and thank you for all your help! One last question if I may, and an updated file is attached... my main loop doesn't respond (button triggers blinking light) until I load the file and run it. in the interim, it hangs. Is it pending on that queue? how can I mitigate this situation?
Message 32 of 39
(1,216 Views)
Yes, you should close the queue on your bottom loop, not the middle loop.
Message 33 of 39
(1,248 Views)
Accepted by jedi.engineer
Put a timeout on the Dequeue and put anything that you don't want to run if no data is received on the queue inside the FALSE statement with the Timeout wired to it from the queue. You can leave the True case empty. Remember, LabVIEW is a dataflow language. A node (loop) can only continue when everything it depends on has completed.
Message 34 of 39
(1,235 Views)
I think we might have gotten off track a little from the original topic, when we went down the road of the producer-consumer structure, which can be a help, I think. What I'm trying to do is this:
  • open a text file that contains scripted commands, as in the example I gave.
  • process commands in my "main" or "consumer" loop.
  • When a "WAIT" command comes through, commands to the "main" or "Consumer" loop are paused until that "WAIT" command finishes, without pausing my main loop.
How would you pause a loop..... without pausing a loop?
I'm guessing you meant without pausing your producer loop?
As others have said it's hard to give suggestions without seeing how the whole program is put together. It seems your question really can only be answered by looking at the architecture of the rest of the program. I edited your uploaded example VI with some notes on what I think you want, or at least an example of what might work. Mainly I got rid of the second loop and put the event structure in a while loop (this is pretty standard structure for handling UI events). The producer loop (the top UI loop) can respond to other events and keep running in parallel while the consumer loop can do longer processes.
One note I made is that if possible I would just pass the file path to the consumer loop and have it perform the read and parsing functionality you currently have in the event structure.
@StevenD - thanks for the input. As I said in several of my replies, I'M RESTRICTED for some pretty damn good reasons, from disclosing my whole program, which is why I made the sample program. I get it, you need to see it. And as I've told the others who asked, there's nothing I can do about it.
On that note, what you sent back is the current structure of my main program. The problem I ran into, as my title explains, is that my main loop pauses when I execute a WAIT command. I only need it to delay the execution of the subsequent commands, and I need my main loop to execute continuously while the WAIT command is executing.
None the less, I thank you for your input.
Message 35 of 39
(1,230 Views)
What I'm attaching is an old CLD sample exam that I did for my CLD prep. It also involves reading steps from a text file, and going to the next step when the time of the previous step has elapsed. Maybe looking at this will be a complete waste of time for you, maybe not.
The two states in this that are most pertinent to what you are trying to do, are "Run" and "StepChange". I'll show a pic of the "Run" state for the class. It's from a while back and kind of ugly, so don't judge me anyone.
So here, the Run state is self-enqueueing. I check a timer FGV to see if a certain amount of time has elapsed. If it hasn't, I just enqueue Run again. If it has, that's when I do what I need to do to get the next step going.
Now, my specific implementation was to keep a shift register of remaining steps to do. When time elapsed on a step, I delete it from the array and that's how I keep track of what I have and haven't done. The takeaway is that what I didn't do, was read my entire list of steps and enqueue everything at once from the get-go. Which is what you are doing.
Whew, what a throwback. Again I don't know if this will help you or confuse you even more but there ya go. Hopefully the former...
Redhawk
Message 36 of 39
(1,222 Views)
Now, my specific implementation was to keep a shift register of remaining steps to do. When time elapsed on a step, I delete it from the array and that's how I keep track of what I have and haven't done. The takeaway is that what I didn't do, was read my entire list of steps and enqueue everything at once from the get-go. Which is what you are doing....
So ... you've implemented a queue. 😉
Qestit Systems
Certified-LabVIEW-Developer
Message 37 of 39
(1,196 Views)
A little confusing, but I get most of it - maybe the shift register approach should have been taken from the beginning, but for me to go back and change it now would take a while, especially since I'd need a self-sizing array, because some of these scripts may be set to run for more than 24 hours... and I'm about out of time to reprogram anyway. But thanks for the input!
Message 38 of 39
(1,173 Views)
Thank you, this has worked.
Message 39 of 39
(1,125 Views)
