Peak detection from waveform data
Hi Folks.
This is probably an obvious one but I cant figure it out. In the sine wave detector VI attached the peaks are determined from a simulated signal. I want to be able to do the same with a waveform data (DBL) but it wont let me. How can I extract the signal from the DBL to feed to the rest and make the waveform peak detector VI work right??
Mark.
(3,973 Views)
Accepted by MarkGreally
Use From DDT, found on the Signal Manipulation Palette, to change the Dynamic wire into a Waveform.
(3,959 Views)
Thanks Bob.
That did the trick.
(3,951 Views)
