Peak detection of a surface - laser spot tracking
Hi Devin_K. I've downloaded the NI-IMAQ driver you linked, and have also run the setup.exe file. However, the driver seems to not have integrated into my LabVIEW installation. Is there anything else I need to do to get IMAQ to work?
Message 31 of 32
(525 Views)
The post you're replying to was last used in 2012 and I'm pretty sure the link in the post you're referring to is from 2005.
I'd venture the reason it doesn't work is you're trying to use software from 14 years ago.
I would recommend that you search for a more recent download (say, from the last 3 years).  Failing that, try posting a new thread instead of responding to one that is 7 years since it was last looked at.
Message 32 of 32
(515 Views)
