Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Β·
Login
Β·
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results forΒ
Search instead forΒ
Did you mean:Β
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Peak detector
Peak detector
quinga
Member
β06-19-2007
05:14 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hello my name is Joaquin.
Im using peak detector but I cant get any signal from it. Where is the problem?. Im using a load cell and in the first graph i have a good result, but with the same signal I dont have any result for peaks detection.
Thanks!
1 sensor with limit.vi β304 KB
0
Kudos
Message
1
of 2
(2,778 Views)
Reply
Re: Peak detector
AnalogKid2Digit
alMan
Trusted Enthusiast
β06-19-2007
11:13 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You may need to set values for threshold and width inputs to the peak detector vi's. Look at the help for the function for more details.
"Itβs the questions that drive us.β
0
Kudos
Message
2
of 2
(2,755 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
