Peak detector
Hello my name is Joaquin.
Im using peak detector but I cant get any signal from it. Where is the problem?. Im using a load cell and in the first graph i have a good result, but with the same signal I dont have any result for peaks detection.
Thanks!
(2,851 Views)
You may need to set values for threshold and width inputs to the peak detector vi's. Look at the help for the function for more details.
(2,828 Views)
