07-09-2024 06:13 AM
I have a graph which have multiple peaks in it, firstly i wanr ti find those peak and then the subset of those peaks.
Can anyone help to do
Solved! Go to Solution.
07-09-2024 06:41 AM
Hi komal,
Use the PeakDetector on your measurement data to find the peaks.
What is a "subset of the peaks"?
07-12-2024 02:15 AM
IMG_20240712_124226.jpgI am attaching the image below, do tell me how i can do so because
07-12-2024 04:40 AM
Hi komal,
What have you tried so far?
Did you try the PeakDetector to find your peaks yet?
Are there peaks with an amplitude less than other valleys between your peaks?
You may search for peaks first, then search for valleys between your peaks.
Then use the valley positions to create subsets from your waveform data…
