Peak subset
I have a graph which have multiple peaks in it, firstly i wanr ti find those peak and then the subset of those peaks.
Can anyone help to do
(1,390 Views)
Accepted by topic author komal2031189@akgec.ac.in
Hi komal,
Use the PeakDetector on your measurement data to find the peaks.
What is a "subset of the peaks"?
(1,378 Views)
IMG_20240712_124226.jpgI am attaching the image below, do tell me how i can do so because
(1,317 Views)
Hi komal,
What have you tried so far?
Did you try the PeakDetector to find your peaks yet?
Are there peaks with an amplitude less than other valleys between your peaks?
You may search for peaks first, then search for valleys between your peaks.
Then use the valley positions to create subsets from your waveform data…
(1,293 Views)
