PeakDetector on top of DBL Waveform
I have a DBL waveform that I want to find the peaks in. I feed it into the PeakDetector, but can't figure out how to place the output of the peakdetector on the same plot as the DBL waveform. In the end I want the peakdetector data to output to a data file with the same time-domain as the DBL waveform.
Here is a picture of the current situation.
Thanks!
(2,834 Views)
Here is another screenshot.. This time I've replaced the peak detector with the Waveform Peak Detector VI. Still though, how could I have both the original plot and the peaks on the same plot?
(2,822 Views)
Accepted by ap8888
You can use XY graph to plot both the input waveform and detected peak locations.
Please see the code.
Best Regards,
Michael
(2,804 Views)
