Periodical task
I need to program a part of the code is executed periodically every so often, ie every 1 hour or every 6 hours.
(4,001 Views)
Inside of a loop, compare the time using get date time with your target time. Use a case structure to execute the code you want periodically executed. Don't forget to put a 1000mS or so delay in the loop so it doesn't hog the CPU.
LabVIEW 2012
(3,997 Views)
Here is a simple example. (I was on my phone when I posted so obviously could not work up an example for you)
LabVIEW 2012
(3,989 Views)
There are also a couple examples of a simple timing Action Egnine posted in the Minneapolis LUG board here
The AE approach is a bit cleanre if your vi follows a classic State Machine archtecture.  It probably should from your discription containing Init, Measure, (possibly  Process / file), Idle and Cleanup states.
(3,983 Views)
Accepted by Redney
Elapsed Time Express VI on the timing palette.
(3,980 Views)
