Phase noise measurement
Has anyone any info or experience in LabVIEW to make phase noise measurements using a spectrum analyser? We have a Rhode & Schwarz FSU (of which we have quite some knowledge) connected via GPIB.
Thanks.
(3,580 Views)
If you have the knowledge that you say you do then it should be quite easy as long as you know the GPIB commands.Here is a little VI that I wrote to do this on an HP analyzer maybe it will give you some insight as to what you need.
Joe.
"NOTHING IS EVER EASY"
(3,572 Views)
Joe,
Thanks for info. Will pursue.
Chris
(3,548 Views)
