Phase noise mode for Agilent MXA N9020A
Hi Ray,   I could not found MAX and Communicate with Instrument. I am now in the system with Labview 2009 only. Do I need to have some Labview Software to have all the function you mention on your instruction?   Could you attach some for me to see it?  Attached is some of example of MXA N9020A, you have to download the NI driver to see it. Could I use it to modify or add some command for phase noise? If yes, how I have to do?   Thank youSteve
Message 11 of 14
(1,533 Views)
You could use one of the sub-vi's and modify it.
Can you zip the folder that contains all the VI's within the one that you posted?  (Initialize.vi, etc..)
If you provdie them, I can modify one as an example for the Phase Noise.
R
Message 12 of 14
(1,524 Views)
Hi Ray,
Attached is the one you ask.
 Thank you
Message 13 of 14
(1,519 Views)
I will (try to) look at it later today.
R
Message 14 of 14
(1,500 Views)
