Pick up values with mouse
Hello !
Can someone tell me how to pick up values with mouse
from a graph. I have a graph plotted and I want to
collect some values from the graph into a table.
I have Labview ver 6.02.
Jack
(2,914 Views)
Jack,
Turn on the cursor. The cursor will display the x and y value in its display (when you also make it visible.) Then you can write the values down.
Also, what values are you looking for. There may be a way for you to use a routine to search for certain values.
Hope this helps
(2,914 Views)
There is a graph-cursor example that comes with LabVIEW that might be of some help. It is found under Help >> Exmaples >> Fundamentals >> Graphs and Charts >> Graphs >> Zoom Graph.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,914 Views)
