Pico Tech Adc-212
Hi
im having a problem of an exception ocurring when I use the 'call library function node' to initializse my ADC-212 im not sure what else I can try.
Gordon
(2,732 Views)
Accepted by topic author Gordyh
Exceptions occur mainly because the parameters you pass are of the wrong data type.
The example that ships with labview
C:\Program Files\National Instruments\LabVIEW 2011\examples\dll\data passing
does give you a  lot of information on different data types.
Hope that helps.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,729 Views)
