Picoscope adc 200/20
I'm struggling to get continuous data recording from a Picoscope adc 200/20, using this code (which I've modified from the examples on the pico website).
I have posted on thier website, but it's very quiet over there. If anyone has an example for this or a similar (parallel port) picoscope I'd be grateful for your help, you could tell me how the code should flow?
Many thanks
Graham
(2,669 Views)
Hello Graham,
As this is not our code and I have no idea how the DLL's are written, I’m afraid there is not much I can do to help you. Your best bet would be to contact Picoscope and ask them for support, which they should provide with their hardware. At NI we always support our hardware and any code we write for the device is thoroughly tested before it is released.
If you are only interested in the flow of the code you could potentially use the highlight execution tool, and step your way through the code, which may help.
Sorry I cannot be of more help.
Regards
Andrew George @ NI UK
(2,632 Views)
