unable to create opengl context
Hi all,
Have a strange problem with my LV7.1 (500908-01G).  Windows security updates are constantly being pushed to the machines so I don't know when the issue first took place.
Symptoms are : once my test code is loaded and the front panel displayed no icons appear, only the text label that goes with them.
I now also have to force the program to quit as it [and LabView] become unresponsive.
Looking at the error logs I see multiple entries for "DWarn: Unable to Create OpenGL context for 3d controls."
I've found another forum reference to Mesa3D, but upon investigating that I cannot find the necessary Win DLLs.
Any ideas ????
Also, a real quick one : 32bit LabView2010 running on Win7 : can the built application from this Windows version run under XP also ?
(3,800 Views)
For LV 7.1 I would first suggest you try backing down on the graphics accelerator settings.
Ben
(3,784 Views)
I went through the graphics acceleration settings reaching the minimum "everything off" state, but this did not cause the icons to return.
(3,773 Views)
Hi Mad Bob,
Can you try a few things so we can pin point the problem better.
- If you hover over where the controls should be do they appear?
- Have you tried removing a control and then replacing it again
- Are you able to run this code in a newer version of LabVIEW?
- What particualr controls/indicators are you using?
- Can you run your code on any other machine that has LabVIEW installed?
Let me know how you get on.
Mahdieh G
National Instruments UK&Ireland
(3,712 Views)
and also your application that was created in Windows 7 will run under XP too. Just make sure you have the right runtime engine installed on the target machine.
Mahdieh G
(3,711 Views)
