Picture constant from custom image file / clipboard image
Dear members!
Please help me with this!
I'm a student on a Bsc course, would like to use this for animation in homework project.
Yours Gergo
(4,570 Views)
Can you be more descriptive on what exactly you want to get done?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,568 Views)
Dear Adnan!
There is a .vi among the examples called force mass-spring-damper in LV2009.
This contains an animation where the an animated object (car) is given by a picture constant. I would like to make a similar animation, but I couldn't input the picture constant.
How can I add it?
(4,556 Views)
Accepted by auerlg
I don't have the toolkit needed for that example on this machine. But, I believe the following KB article should answer your question:
How Can I Programmatically Insert An Image Into A Picture Control and Resize The Control?
Let us know if it doesn't.
Adnan Zafar
(4,552 Views)
Thanks a lot for Your help Anan!
This is the solution to import a picture, after that a constant with the image could be created too!
Respects
Gergo
(4,540 Views)
