Play pink noise over BNC-2110 board
I have connected a speaker to my BNC-2110 acquisition board through an amplifier.
How do I play pink noise for e.g. 10secs, I need an example VI please?
I use LabVIEW 8.5 and I have Sound and Vibration toolkit installed.
Best regards
Simon
LabVIEW 8.6 / 2009 / 2010
Vision Development Module 8.6 / 2009 / 2010
VBAI 3.6 / 2010
(2,713 Views)
The first thing you will have to do is get a DAQ card connected to your terminal block. The BNC-2110 cannot generate a thing.
Second thing is to do a search for 'pink noise'. I did that and come up with this.
(2,701 Views)
I found out that it actually was quite easy with the Sound and Vibration toolkit. With this toolkit, all I needed was to use the VI, SVT Pink Noise Waveform and connect it to the express VI DAQ Assistant to make my speaker play the pink noise over the board via an analog channel. With adding some simple buttons to the frontpanel, I can control playtime and amplitude, quite simple. Please see attached image.
VBAI 3.6 / 2010
(2,694 Views)
