labVIEW installation error.HELP
I am getting this error while trying to install labVIEW.I formattted the system. Is my back up corrupted?
Message 1 of 13
(6,766 Views)
Message 2 of 13
(6,757 Views)
I downloaded the ini file and the problem is solved. But very weird and can some tell me why the file in my bin folder suddenly vanished.
Thanx for the link mathan
Message 3 of 13
(6,747 Views)
"Developer Error. The following errors were found in your file:
1. Specified file not found: [Utilities] UpgradeManagerPostProcessor = Bin\niPie.exe
Correct the ini file and try again."
I am getting this error again while installing vision assistant
Message 4 of 13
(6,743 Views)
I am still stuck.I think i will start a new thread with a better error description. What dya say mathan?
Message 5 of 13
(6,720 Views)
Dear muks,
Better you can give the detailed description here itself. Anybody facing the same problem or anybody had that same problem previously and solved by mystery will surely guide you here.
Hope you understand.
Mathan
Message 6 of 13
(6,716 Views)
Mathan,
             I dont think so.I even tried renewing a old thread yesterday.But sadly i think brian.T is not active nowadays.He had posted an inif zip file on the page which you reffered me and i was able to install LabVIEW but am not able to istall the device drivers and vision using the same inif file so i need some one to post the inif file.By any chance mathan can you do it.It will be inside the bin folder in the LabVIEW cd.Can you do it?
Message 7 of 13
(6,714 Views)
Hi muks,
Are you looking for someone to post niPie.exe for version 8.5 of the Vision Development Module?  I have attached that file in Vision Development Module.zip.  Hope it helps!
Jennifer R.
Message 8 of 13
(6,679 Views)
Yes I was.And thanx a ton for posting it,Jennifer.
Message 9 of 13
(6,665 Views)
Hi Jenifer,
                  I am still getting this error
Message 10 of 13
(6,660 Views)
