Play wav file and stop playing
Hi all,
What i exactly need is to play a lengthy wav file. I am able to achieve this. But amidst "Play output.vi" is playing the wav file, i must be able to stop the play in the middle. Is it possible?
Your help is greatly appreciated.
Muthuraman S
Muthuraman
Message 1 of 11
(4,712 Views)
Are you sure the name of the VI is "Play output.vi"? Is this a custom VI that you have built?
If so then you will need to open the block diagram of this VI and check the code.
Message 2 of 11
(4,687 Views)
you could use this library
I hope this helps:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 3 of 11
(4,683 Views)
I leave an example which can contribute, Greetings
Message 4 of 11
(4,243 Views)
Please stop spamming all these messages with your "example".
Message 5 of 11
(4,237 Views)
thank you very much for the bounding, the objective of the forum is to help only propose a simple example that anyone can understand, if you can review the same issue is with different questions, plus there will always be people who are just starting, Greetings
Message 6 of 11
(4,227 Views)
No, this is absolutely unacceptable behavior. If everybody would post their stuff in 10 different places, the forum would be 10x harder to use because of all the noise.
As has been mentioned, your example is actually pretty bad and it will give poor advice to new users.
Next time you create an example, post it in a new thread and ask for feedback and improvements first.
Message 7 of 11
(4,215 Views)
What the heck is a "bounding"?
Message 8 of 11
(4,211 Views)
bounding, means when you have to stop in any case thanks, but we're getting off the thread
Message 9 of 11
(4,196 Views)
What case?
Message 10 of 11
(4,184 Views)
