Please Help me with the DAQs
Hi Everyone,
My VI is supposed to take input from a pair of infrared sensors, A Photosensor and a Thermocouple. But, I am unable to find a DAQ that would suit all of it. Can anybody help please. I don't need a high sampling rate. A moderate DAQ would be just fine!!
Thankx!!!
(2,826 Views)
Hello Rishabh,
                   Please let me know, which kind of output do you have for all these.. I guess NI USB 6008 would do your job..
Hope this helps you,
Nitzy...
(2,814 Views)
 I need a windows based system with a DAQ of sampling rate as low as 8-24 samples/sec. I am sampling the signals by statistical methods(taking the mean). My output requirement consists of purely On/off signals which will be used to activate/deactivate certain devices.
 I require my thermocouple to be sensitive for some 8-50 degree celcius range with minimum resolution being of the order of 2-3 degrees.
I had initially selected USB 6008 for my purpose as it was a cheap and optimum performer. but, i have read that the thermocouple reslution will rise to somewhere around 10 degrees. How far does the truth goes??
I hope this info might suffice to give u the clear idea about my requirements.
Rishabh
(2,796 Views)
The USB-6008 is not a good choice for thermocouple measurements. It's just an analog input module, and thus provides no compensation for thermocouples. A more thorough explanation, including a suggested module, can be found here: Thermocouple Measurements with the USB-6008 or USB-6009. If you don't want to use a thermocouple-specific module then you must make sure you design and use the proper signal conditioning to allow you to connect it to the USB-6008 and still get accurate measurements.
I would suggest that you contact your local NI sales office, as they are very capable of helping in these kinds of situations.
(2,780 Views)
