multi list box
In muliti list box, we can center string by CellJustify property. This is horizontal center. But if i want to
set vertical  center. Which property should i use? Please see my attached file.
By the way, color of Scroll bar is not suitable to my list. How can i modify it?
Thanks.
br
(3,757 Views)
HI, all.
Sorry for my subject. It should be a question about how to set vertical center in mulitbox list.
thanks.
(3,756 Views)
I have no idea how to center text vertically.  For you second question, you can change the color of the scroll bar with the 'paint brush' on the tools pallette.  The upper color changes is the color of the arrows, and the lower color changes the color of the scroll bar.
(3,735 Views)
If you are using a system control, you can't edit the scroll bar.
Message Edited by Broken Arrow on 08-28-2009 03:28 PM
Richard
(3,719 Views)
Vertical alignment is not supported. Didn't see it in LV 2009 either. There was a similar idea posted in the LabVIEW Idea Exchange regarding string indicators. You may wish to add a new one requesting this feature be added. It's long overdue.
(3,698 Views)
hi All
Thanks all of your help.
(3,671 Views)
