Please, How do change of the cursors position of
using controls ?
How do it?
Thank you very much,
Juscelino
Message 1 of 17
(3,857 Views)
Hi Juscelino,
Can you provide more details?  Change the cursor (s?) position of what?  Waveform Graph? Chart? Table?
Change the position to what (or where)?
Most likely there will be a Property Node involved somewhere, but unless we get more details, it is difficult to provide any advice.
Message 2 of 17
(3,853 Views)
I have some  graph xy with two cursors implemented with the difference between x2-x1 and y2-y1 in each of them.
with the application running, I need of to reposition the cursor in two specific locations.
they are always on top of the curve and for example I need of place cursor numero 2  exactly in position 200, and  the numero 1 exactly in position 155.
the idea is to use a control to bring the cursor to the desired position.
I send attached the property node that I'm using to make the x2-x1.
Juscelino
Message 3 of 17
(3,843 Views)
I send property node that I am using.
Obrigado,
Juscelino.
Message 4 of 17
(3,830 Views)
I did this recently.  I want to have a pair of cursors that move to a region that I'm interested in.  This snippet will add a pair of cursors, removing them is as easy as feeding an empty array to the CrsrList node (which I do in another state). The subVI is just a cluster constant, it's there to save space on the BD.
Jim
Message 5 of 17
(3,809 Views)
Sorry, But I did not understood, how can I to do it ?
Thank you
Juscelino
Message 6 of 17
(3,766 Views)
Please, whwere can I find this icon ?
Message 7 of 17
(3,759 Views)
sorry,
Thank you ,
Juscelino
Message 8 of 17
(3,758 Views)
Sorry,
Please, where can I find this icon ?
Thank you,
Now with anex
Message 9 of 17
(3,756 Views)
You really only have to ask once.
As mentioned, it's a cursor constant saved as a VI. Right click on the graph and select Create>Property Node>Cursor>Cursor Position>All Elements. Right click on this and select Create>Constant. Save it as a VI or not. Up to you.
Message 10 of 17
(3,751 Views)
