Please help , insert 1d array into 2d array
Hi
I'm trying to insert a row of 1d array into 2d array but it has to be placed at the desired index as the starting point.
For example,  row 1 , column 2. = starting point.
I already wrote the program but the result is not that i want.
As shown in the picture, a number 6 in (0,2) , it should be placed in a yellow highlight.
Please help and guide me.
(6,436 Views)
(6,422 Views)
Accepted by topic author fattynoon
Hi fatty,
use shift registers:
It's maybe a good idea to include some range checking as it's not possible to replace non-existing elements...
(6,415 Views)
Many thanks GerdW Smiley Happy
So, it's mean that I have to replace an element at a time right?
Can I replace an entire row at a time?
(6,405 Views)
Hi fatty,
yes, you can replace a complete row - when you only wire the "row"! input of ReplaceArraySubset. But you wanted to replace only some elements of a complete row...
Otherwise that operation would be not properly defined: in a 2D-array you can replace rows and columns. When you wire both row and column index, you have no option to define "replace row" or "replace column"...
(6,402 Views)
