Please tell me how to use the Simple bluetooth client server example.
Hi i used the simple bluetooth client server example in labview 7.1. Iam getting an error saying your system does not support the network operation.  I have following doubts also.
1. Should i pair the device before running the labview.
2. Should i enable the file transfer wizard in the software given with the bluetooth adapter.
Please help
Thank you
R.Prem kumar
09940446193
(2,479 Views)
Hi R.Prem,
Could you please let me know what error code is associated with this error message? Also could you please provide a description of the setup you are currently using? Thanks!
Steven
(2,459 Views)
