Plot Data versus Date without Time (i.e. only 3/3/14 not 3/3/14 05:43:63 PM)
I have data by dates I want to plot in LabVIEW. These dates do not have a time associated with them, they are only 3/3/14 for example and in string format. How can I plot these like in excel with the data plotted against the date.
Thanks!
(2,736 Views)
Hi John,
simple solution:
Plot your data on a XY graph. Convert your x data to timestamps, the graph accepts them. Format the x axis to show time using only the date…
(2,730 Views)
Accepted by JohnH123456
To wit, there are a number of options to convert the string to timestamp:
1) Convert your date string to a cluster of numbers using Scan From String, then convert to a timestamp (link)
2) Use some fancy .NET classes (link)
3) Use Scan From String with your string in appropriate format:
This one's a little dirty, however.
CLA
(2,720 Views)
