Plot Graph with Explicit X-axis values and Report with Explicit X-axis Title
Hi all!
While working with graphs and report generator toolkit, I am facing two issues.
In the report generation in Excel, it's actually making nice graphics, but somehow I don't see the option to add a title for "X axis" or "Y axis". There is an option for Graph Title, but not for the Axis title. See the image please.
The second issue is with the Graph control/indicator.
As you can see in the above image, the X axis has data points which are not like index (0-n) but some specific points. In the Waveform Graph, I have to use only the two columns (the gray and blue data) and cannot use the data that has those values of X axis. So it generates the graph, but not quite as I would like it to be. As in the following image.
I cannot find a property value to assign the explicit values to X-axis. I am not talking about the range of X axis. I am talking about projecting my data on X axis (as in the first image above). Of course, unlike in the case of report generator, I am not providing the first colmn data, so obviously it's not going to project it. But I could not find how can I send that data to project as in the first image.
Thanks ahead!
Vaibhav
Message 1 of 22
(9,638 Views)
The first question sounds like an Excel issue.
In terms of your second problem, you are using the wrong XY Graph data type. If you check context help you will see that it supports several datatypes. The one I use a lot is a cluster containing an array of x values and a corresponding array of y values. A multiplot is then just an array of those clusters.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 22
(9,616 Views)
Accepted by Vaibhav
Hi Vaibhav,
generic answer: use an XY graph when you want to plot XY data…
Message 3 of 22
(9,613 Views)
Oops, my bad. I didn't notice that weren't actually using an XY Graph...
So replace the waveform graph like Gerd says, with an XY, ***then*** feed it the right data structure.
Mike...
LabVIEW Champion
Message 4 of 22
(9,597 Views)
Accepted by Vaibhav
@Vaibhav wrote:
Hi all!
It's really counterintuitive, you need to use Excel Set Graph Font.vi (xlCategory for the x-axis, xlValue for the y-axis).
Ben64
Message 5 of 22
(9,575 Views)
Accepted by Vaibhav
@Mike
@GerdW
Thanks. I had tried to XY graph before, but somehow I couldn't manage to present my data correctly, and the example of Waveform Graph convinced me it was easy.
But after your suggestion, read the help more carefully, and tried making the cluster array for multiplot (I was earlier trying with single plot, because I thought multiplot will make 2 separate plots in one window). And it works now as it shows in the Excel's chart.
@Ben
Yes, it's indeed counterintuitive. I always ignored that vi because I didn't want to set font. Smiley Frustrated
It works now.
Posting the updated program for anyone else learning about LabVIEW graphs and report generation.
I would however like to make the Y-axis label (string counts) vertical. Couldn't find that option. Anyone?
Vaibhav
Message 6 of 22
(9,541 Views)
It is not available with the Report Generation Toolkit vis (althought in my opinion it should be since it is not a big modification of Excel Set Graph Font.vi). You will have to use ActiveX to do it.
Ben64
Message 7 of 22
(9,455 Views)
ben64 escreveu
Ben64
Hi Ben,
Thanks for the suggestion.
But how is it possible? Because we're talking about a chart that is being prepared inside the excel, and the chart was already prepared in the report. Can you please give an example?
Vaibhav
Message 8 of 22
(9,442 Views)
Use this vi. Set the axis type to xlValue and the orientation to xlUpward.
Ben64
Message 9 of 22
(9,424 Views)
Thanks Ben,
Can you please convert the VI to 2013? I still haven't got DVDs for 2014 onwards.
Vaibhav
Message 10 of 22
(9,387 Views)
