Plot Graph with Explicit X-axis values and Report with Explicit X-axis Title
Wow! Really good.
Didn't know it was possible to dig this deep inside the object.
But then on the other hand, I am wondering, if it has all these properties, including Orientation, then why aren't they simply accessible from the included VIs.
Thanks a lot!
Vaibhav
Message 12 of 22
(2,423 Views)
There are too many different graph objects and properties. Some of these properties also do not apply to all graph types. But in this case I think axis title orientation would be a grat addition.
Ben64
Message 13 of 22
(2,404 Views)
Ok.
Analysing your blockdiagram raised a few questions in my mind.
Why are OLE objects' indices a +1 than the actual index of the object (they start from 1 instead of from 0?).
Why is the index not a number but a variant? Indices are always numbers, no?
And after you have selected the object property, how come it became chart? In the beginning you are just selecting Shapes. And it could be some figures (square, round etc.) and not only a chart.
I don't know if my questions make sense. The usage of application property nodes seems to be very empowering.
Vaibhav
Message 14 of 22
(2,389 Views)
@Vaibhav wrote:
Ok.
Yes, they start from 1
No, for some object, like worksheet, it can be the name of the object.
I recreated the input of the RGT vis. If you don't wire the index input it uses the default value of -1. When index is set to -1 the OLEObjects index used is the shape count. Since the graph was just created the shape count is the index of the graph just created.
Ben64
Message 15 of 22
(2,372 Views)
@ben64 wrote:
Use this vi. Set the axis type to xlValue and the orientation to xlUpward.
Ben64
Thanks for that VI.
I was able to play with it to change the major unit for the Y scale, but I am trying to change the major unit for the X axis scale.  How would I choose the X axis to modify it?
I am guessing it has to do with where you choose the Excel.Axes class.  I will look at that more after lunch, but figured I would ask.
Message 16 of 22
(2,304 Views)
@_Bryan wrote:
Ben64
Thanks for that VI.
Set Axis type to xlCategory to change the x-axis
Ben64
Message 17 of 22
(2,295 Views)
Ben64
I tried that before and I get an unknown error.  In this snippet if you set the axis to XlValue it will modify the Y major value, but the xlCategory throws an unknown error.  I have noticed that if I even look at the screen wrong the report generation toolkit will throw an unknown error.  So I assume it wants another piece of info somewhere.
Message 18 of 22
(2,289 Views)
You need to attach the modified version of the vi.
Ben64
Message 19 of 22
(2,278 Views)
Message 20 of 22
(2,271 Views)
