Plot Secondary Y-Axis in Excel
I have two series of data and am trying to plot them to a primary Y-Axis and a secondary Y-Axis in Excel using ActiveX.  Right now I have a file in Excel that I am using to test my code that has the values 1 through 20 in the first three columns and is saved as test.xlsx in the filepath C:\Templates\test.xlsx.  I am able to open this file and plot the data in an XY scatter chart and name the primary x and y axes, but cannot figure out how to plot one of the data series against the secondary y-axis.
I created a macro in Excel and viewed the code it created to make a secondary y-axis.  This is the code:
Sub Macro1()
' Macro1 Macro
    ActiveSheet.ChartObjects("Chart 1").Activate
    ActiveChart.SeriesCollection(2).Select
    ActiveChart.SeriesCollection(2).AxisGroup = 2
End Sub
When I try to do this with ActiveX, I can select SeriesCollection(2), but when I choose AxisGroup, it is only a read function and I cannot write a 2 to it.
Is there another way to plot one of these data series against a secondary y-axis.
(4,789 Views)
Noxen,
  Which ActiveX Call specifically are you trying to call? Can you link the MSDN page of it?
Regards from Austin,
Ben J.
(4,742 Views)
The attached image was the way that I would have thought I was supposed to create the secondary axis by writing a 2 or xlSecondary to the AxisGroup, but it does not work because AxisGroup is Read Only and I cannot write to it.
http://msdn.microsoft.com/en-us/library/aa141701%28office.10%29.aspx
If I create a secondary axis using a macro, I can act upon that axis.  However, I am not able to create the secondary axis without a macro, which is what I would really like to do.
Ryan
(4,735 Views)
Ryan,
  Unfortunately I am having a tough time navigating Excels ActiveX library to find what you are looking for in order to add that second Y-axis. The MSDN site you pointed me to was Visual Basic, not ActiveX as well. Could you find the ActiveX call on the MSDN site?
Ben J.
(4,711 Views)
This is the link in the MSDN for the Axis Group in ActiveX.
I do not know if this is the correct ActiveX call to create the secondary Y-axis.  This is the main problem, I cannot find the correct ActiveX call to create the secondary axis.
(4,695 Views)
(4,694 Views)
Noxen,
  Unfortunately I do not know which call to use either. Hopefully someone with more ActiveX experience will be able to shed some light on the correct way to achieve this second y-axis.
Ben J.
(4,675 Views)
