Plot function and Interpolate Plz Help!!!!
Thank you !!!above graph is  what i wanted. now do i have to feed array values to interpolate 1D to get I values when some V value is specified?
Message 11 of 12
(616 Views)
Hi Hillary,
two notes:
- replacing the feedback node by a shift register will enable users of LV upto version 7.1 to recreate this vi
- renaming BMP to JPG doesn't change the filetype (I vote for enabling a filter in the forum filtering out BMP files Smiley Sad), saving your pic as PNG will result in filesize of ~100kB instead of your 3.5MB BMP...
Message 12 of 12
(610 Views)
