Plot multiple y axis from csv file
Hi All,
I have the attached csv file. And I want to be able to plot the first column as the x axis, and the second two columns as two separate y axis on the one xy plot.
I am not sure why my coding is not working.
Thanks in advance.
(4,593 Views)
Go into your graph's property settings.  Go to Plots page.  make sure your 2nd plot is set for the 2nd Y-axis.  Right now they are both assigned to the 1st Y-axis.
Use Block Diagram Cleanup to straighten your wires.
(4,584 Views)
Thanks for the quickreply RavensFan.
However, I thought they were on different axis? Please see screenshots of properties
(4,579 Views)
Accepted by ENGINEERALEX
I swear the first time I opened your code, it looked like the properties weren't set that way.  But after your message, I closed and reopened and checked again.  They were.
I do see problems with your Read Spreadsheet file function.
1.  You are only reading 3 rows.  Delete that 3 constant.
2.  You don't have a constant set for delimiter.  Unwired it defaults to a tab.  You need to add a string constant and put a comma in it.
3.  Your index array is picking Rows 0, 1, and 2.  You want to pick Columns 0, 1 and 2.
When I fix those things, I see two lines and both stretch the full length of the Y axis, each on its own with different Y scales.
EDIT:  Actually something is odd about the way you wired your data.  Your column 0 became the Y axis for both,.  And columns 1 and 2 become X axes.  When I go and fix your auto-scale issues on the graphs, your graph axially looks like the second chart.  I think you mixed up your X and Y columns.  Make sure you understand how your data is saved in your file, and understand the differences between rows and columns, and the order that you bundle the arrays to make a plot.
Graph%20plot-1
After fixing X and Y axes so they all auto-scale
Graph%20plot-1
(4,570 Views)
Those steps sorted it!
I had my inputs to the bundles the wrong way round, looks much better now.
I really appreciate your help with this issue, thank you!
(4,543 Views)
