Plural of VI
What is the correct way to make VI plural? Do you use an apostrophy
even though it is not possesive?
Example: Move the (VIs or VI's) to the root directory.
Toby Stensland
toby@stensland.com
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(5,720 Views)
Neat question. Strictly speaking, I think it should read "VIs"
(because, as you pointed out, it's not possessive). But then again, I
like to use apostrophies with acronyms to avoid confusion.
Rick Nelson
Chesapeake Sciences Corp.
1127B Benfield Blvd.
Millersville, MD 21108
Tel: (410) 923-1300 x3430
Fax: (410) 923-2669
(5,720 Views)
The National Instruments internal documentation convention is "VIs" in
this case (check the LabVIEW manuals or any NI Web content), and we tend
to avoid the apostrophe for other technical acronyms as well (e.g.
"DLLs").
--John Lum
> Rick Nelson
> Fax: (410) 923-2669
(5,720 Views)
