pausing to wait for user input
Does anybody know how I could semi-automate a test by asking the user to
make a measurement half way thorough the program and then continue when
they have entered it?
Jenni
Please reply to jbuglar@cadence.com
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(10,618 Views)
Just have the program run into a WHILE loop, and inside the loop just have
the digital control. Just keep the loop going until the digital control is
not equal to zero. (or whatever value you want).
In the case the measurment might be zero, you could have it as a string
control, and as long as it is not a 'space', (a function in the compare
menu) keep the loop going. Then immediatly change the string to a number.
(found in the strings menu).
Another way is to have a digital control and only have it register when an
"enter" button his hit (boolean).
Rick
(10,618 Views)
Aside: Don't forget to put a pause timmer of say 100ms in the loop or the
performance of your computer for other tasks will plumit as Labview will hog
the processor - doing the loop as many times as it can per second....
Peter
(10,618 Views)
> Peter
Oh yeah, good point. I forgot about that. I hope in the next versions you can
set a default timer value for while loops, cause I always have timers like that
it my loop -- gets kinda redundant.
Rick
Chesapeake Sciences Corp.
1127B Benfield Blvd.
Millersville, MD 21108
Tel: (410) 923-1300 x3430
Fax: (410) 923-2669
(10,617 Views)
