Plz convert my labview 8.5 file to labview 8.2
Hi, can anyone Plz convert my labview 8.5 file to labview 8.2 & return it back to me. I will be highly obliged.
Thanx
(3,254 Views)
Umm ... we would need the file to do that :).
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,249 Views)
You can do this yourself.
Open the VI in 8.5.  Under the "file" menu, select "save for previous version".  Choose version 8.2.  And there you go!
(3,242 Views)
Not necessarily.  It is possible he has a LV 8.5 file from somewhere else and doesn't have LV8.5 or newer to be able to open it.
(3,229 Views)
yeah guys, I dont have labview 8.5. And also I am not willing to install it just for this one file....
I am attaching the file with this message, Plz convert that to labview 8.2 vi & then post it back.
Thank you very much for helping me.....!!!
(3,202 Views)
Accepted by laeeq
Here you go.
If you use it, it needs a lot of work as local variables are abused.  There are while loops that only run once for no reason. And serial ports being reconfigured on every loop iteration.
(3,194 Views)
