Polar Intensity Plot - new idea??
Here is a hacked together llb that might get you started in version 8.6
Message 21 of 46
(2,027 Views)
damn should have said i'm on lv8.2, could you convert for me?? the most up-to date copy we have is lv8.5 in the department,
Sorry!
Message 22 of 46
(2,024 Views)
Here it is as 8.2 but there were a bunch of errors when saving.
Message 23 of 46
(2,022 Views)
Here is the 8.5 version while we are at it.
Message 24 of 46
(2,019 Views)
yeah its not fond of either the Scenemesh or the Autofocus components of the VI in lv 8.2
do they have an alternative in lv 8.2?
Message 25 of 46
(2,003 Views)
No idea. I don't have 8.2 to check it out. I started with the demo file C:\Program Files\National Instruments\LabVIEW 8.6\examples\picture\3D Picture Control\Using Meshes.vi.
Message 26 of 46
(2,002 Views)
I've got the same VI in lv8.2, same address, its a little different in setup but, it looks to support the same stuff.
see attatched, any difference to your example?
Message 27 of 46
(1,999 Views)
I'll have to make a printout of my vi's as pdf files and attach them.
Message 28 of 46
(1,991 Views)
If you could, that would proberbly be the best way,
can i ask, did you get it to work, a interpolated intensity plot that is??
Thank you again for your time on this.
John P.
Message 29 of 46
(1,982 Views)
I think it does what you want as long as it was only colored datapoints that you wanted. If you want colored regions it will take some more work. Attached is a screenshot.
Message 30 of 46
(1,974 Views)
