Polar Intensity Plot - new idea??
Thats fantastic, its 90% of what i was hoping for, i would like coloured interpolation, a solid block shape over the whole area,
is that possible??
For the want of a better image, i've attatched an odd example, but its the best concept idea i could get on googleimages.
Message 31 of 46
(2,776 Views)
Take a look at this link for what can be drawn with the mesh datatype. I'm not sure if we would have to apply a texture or use the polygon fill. We might be able to simulate it by changing the dot size. The real trick will be figuring out whther to use triangles or quads, and the fill color between vertices.
http://zone.ni.com/reference/en-XX/help/371361E-01/lvconcepts/3d_meshes/
Message 32 of 46
(2,768 Views)
Message 33 of 46
(2,767 Views)
Here is an option with the old 3D graph.
Message 34 of 46
(2,752 Views)
Hi... could you convert the file above into lv 8.2, sorry to ask again.
any luck with the change to spots?
Message Edited by John Pierson on 10-02-2008 06:01 AM
Message 35 of 46
(2,733 Views)
Here is the 8.2 version. I'm not sure yet about drawing meshes instead of points. You have to send a group of vertices for each mesh region, and I haven't figured out how to group them yet.
Message 36 of 46
(2,731 Views)
Yatta!!
I've got what i needed working, i applied a correction to the spherical plot that i previously had. i had the problem of the dat aobscuring other parts of the data. So by applying the following corrections to each point, it 'leans' the data back so to only occupy a designated possition,
The equations are:
Rc = sqrt(R*sin(90-theta)^2 + theta^2)
thetac = asin(theta/Rc)
Where:
Rc is the 'corrected' possition of R
R is the radius value in Spherical coordiantes
theta is the polar angle from the normal in Spherical coordinates
thetac is the 'corrected' angle for the polar plot
this gives a corection to every point that gives what i deem to be a polar intensity plot.
image attatched, i can make a vi if people would like it and its deemed useful!
Message 37 of 46
(2,720 Views)
Yes, please post the results. I still want to know how to take XYZ point data and turn it into a mesh surface in the 3D picture control. I'm also looking at some mathscript mesh commands.
Message 38 of 46
(2,715 Views)
John Pierson wrote:
Yatta!!
[Set Lurker_Mode = False]
Please do!
I'll tag it once you post it up.
Ben
Message 39 of 46
(2,714 Views)
Hello Ben,
I knew you were out there somewhereSmiley Very Happy
Message 40 of 46
(2,712 Views)
