Polar plot with legend points
I can put one Polar Plot with legend in points?
Case:
I have magnitude and phase arrays for build polar plot and i want put rotation legend in each point of measurement. Then we have 3 arrays (magnitude, phase and rotation), but rotation need stay like legend for each point.
Somebody already do it?
thx for tip.
Leonardo de S. Cavadas
Maintenance Engineer and Inspection - Bureau Veritas do Brasil
Engineer Metallurgist with emphasis in Advanced Materials
Technologist in Computer Science
Message 1 of 10
(5,451 Views)
I'm not sure if this is what you need.
Message 2 of 10
(5,437 Views)
Thanks for tip unclebump,
but i need something like attached figure (sorry by quality - I did with mspaint).
For understand the figure look for a motor in starter, the vibration magnitude increase until ressonance and after decrease (circles in your example - magnitude value), we have phase of event in axis and in each point of measurement the rotations in moment.
Example: In figure, ressonance occur in 60 RPMs.
If you will have other tip for me, very thx.
Message 3 of 10
(5,425 Views)
If you are using labview 8 or higher, try using graph annotations.
http://zone.ni.com/devzone/cda/tut/p/id/3685
The picture control has some functions that let you draw text anywhere in the image.
Post your vi and some sample data.
Message 4 of 10
(5,407 Views)
Thx unclebump,
 my Labview 7.1 haven't this resource, i will try do it with other way. Thx for all.
Message 5 of 10
(5,385 Views)
Unclebump,
 i do one simple modification to be possible add rotation value to image, isn't better solution but i think that i'm near to solution way. Look these VIs, Re-link is necessary.
Message 6 of 10
(5,383 Views)
I can't look at them, I'm still using 7.0.
Message 7 of 10
(5,363 Views)
The polar plot you are looking for is a standard rotating machinery vibration polar plot.  I have attached a screen shot.
This is included in the order analysis toolset
The Order Analysis Toolset works with LabVIEW 7.0 and later.
pages 56 and 57 of the OAT user manual provide more details
Let us know what additional questions you have.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
Message 8 of 10
(5,316 Views)
Thx Preston,
my Boss tell me that buy process is in progress. Thx for all.
Message 9 of 10
(5,293 Views)
Hi unclebump,
I modified your vi to superimpose polar plots from user input data set. Unfortunately, the front panel will not display any plots after the modification. Can you provide some guidance on using your example? Also, the vi only allows 3 plots to be superimposed on the front panel, is there anyway to increase the # of plots allowed?
Thanks!
Attached is the modifed vi and sample data set.
Message 10 of 10
(4,922 Views)
