write / read from XML file
Hi all
I want to build VI in labview that write data to xml file ( save these data ) , then load them
If some one know how to do that , or someone build  in past same thing I would be very thankful to know
wisam
(3,393 Views)
Hi
There are very useful examples shipped with LV. Just have a look at them - it's very easy.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,389 Views)
Hi Wisam,
To get to the LabVIEW shipping examples on reading and writing XML files, launch LabVIEW and then go to Help » Find Examples…  This will bring up the NI Example Finder.  Now, click on the Search tab and search for XML.  There should be a few examples, namely, Write Data to XML File.vi and Read Data from XML File.vi.  These should help get you started.
Donovan
(3,364 Views)
