Polyfit forced through the origin?
Is there an easy way to force a 3rd order polyfit through the origin or constrain it through a point??
(6,775 Views)
The General Polynomial Fit allows you to constrain coefficients but not through fixed points.
(6,766 Views)
Accepted by topic author Deastman
The easiest way (using the functions available in LV) is to set a high weighting to the point you want to cross.
For instance set the weighting to 1 for all points except the origin where you can use a weighting of 100000 or so.
(6,763 Views)
This worked... I created a weighted array populated with conditionally set weightings for the points that I needed to force the polyfit through.  Thanks for your help!
(6,754 Views)
