Polygon_Size Increase Fixed Distance from Points
I believe I may have found a promising algorithm which uses splines ("Offsets of Two-Dimensional Profiles", Tiller et al. IEEE).  Splines are extensively implemented in LV, surely this can be done using them.
Message 11 of 13
(1,091 Views)
Here is the issue demonstrated for convex and concave vertices, respectively.
Possible algorithm:
1. Offset the P vertices in x and y.
2. Place a circle of radius = desired offset at each of the vertices.
3. Find the intersection of a tangent on the circle and the offset vectors either side of the vertex.
4. Insert 2 new points (offset vertices) at the intersections.
Message Edited by battler. on 05-27-2010 07:32 PM
Message 12 of 13
(1,084 Views)
Must have put you all to sleep!  Don't you just find computational geometry invigorating?! Smiley Happy
Message Edited by battler. on 05-31-2010 04:20 AM
Message 13 of 13
(1,050 Views)
