Polymorphic Vi
Actually i have created one Polymorphic Vi that contain the Addition operation with three different data types ..... Now how can i use this it as a sub vi in block diagram
Message 1 of 11
(5,407 Views)
Hi KarthikeyanMathialagan,
insert the main instance of your polomorphic vi into your subvi and select the correct type or use automatic selection.
Mike
Message Edited by MikeS81 on 04-04-2008 06:50 AM
Message 2 of 11
(5,405 Views)
How Mike ....... see i have attached tha polymorphic VI
Message 3 of 11
(5,402 Views)
You should also attach the three different polymorphic instances of it..
Message 4 of 11
(5,399 Views)
Message 5 of 11
(5,387 Views)
open an empty vi and palce your "Poly vi.vi" in it even in the same way as every other vi.
Mike
Message 6 of 11
(5,380 Views)
Mike i can not able to drag the Poly.vi in to new blank vi
Message 7 of 11
(5,375 Views)
Hi Karthi,
i have no problem with it. See the attached example.
Mike
Message 8 of 11
(5,372 Views)
Mike yaa ur program is working how u did man.... can u say the procedure
Message 9 of 11
(5,369 Views)
i do it with drag and drop, but it works in the "normal" way, too. Right click on the blockdiagram and select "select vi" or "open vi" i´m not sure because i have a german version Smiley Sad. Accurately as every other user vi.
Mike
Message Edited by MikeS81 on 04-04-2008 08:09 AM
Message 10 of 11
(5,364 Views)
