I have a LV 8.5 VI that controls only an agilent spectum analyzer. The agilent VIs call DLLs rather than SCPI commands. I created an application and an installer to load on a non LV machine and ran setup which was successful. When I run the EXE I get "error code 3: Could not load front panel" for each of my agilent spectrum analyzer VIs. I have to click "OK" about ten times, once for each VI. (My executable runs fine on all machines that have labview 8.5) The front panel does load with a broken arrow. The errors listed when the arrow is clicked for all of the Agilent VIs state: Missing subVI AGE444xInitialize.VI (or close.VI or read.VI etc.)
There is an AGE444x32.DLL in the data folder with the EXE file so I included as support both the DLL and all of the agilent drivers in the application build. Still no luck. I have built the application and installer about 6 times in various forms. I NEED AIR SUPPORT.
Unfortunately I do not have access to the internet at my jobsite so bear with me.
Rob
